V-REP and fluids
Re: V-REP and fluids
Post by coppelia » 27 Jan 2016, 10:25
The cm part is what will bring each body element to float (i.e. buyoancy). When a body element is higher in the air than 0.05 meters, then it has no buyoancy at all. Otherwise, it will depend how immerged the element is.
rfcarneiro
Post by rfcarneiro » 15 Oct 2018, 21:41
Good afternoon,
I just started working with V-REP and I have lots of doubts. The first one is how can I make this pool that is done in this simulation? Where should I put those scripts you wrote?
Post by coppelia » 16 Oct 2018, 06:31
did you have a look at the demo swimming robot, Models/robots/mobile/ACM-R5.ttm?
Have also a look at this buoyancy example scene.
rfcarneiro
Post by rfcarneiro » 05 Nov 2018, 01:05
Thanks,
I was able to put is to work. Not perfectly well, but it floats and moves.
One more question. How can I do that tank with water showed in the video?
All the best
Rodrigo Carneiro
Post by coppelia » 07 Nov 2018, 07:57
The tank with water is just visual effects. Transparent textures that are shifted dynamically.
rfcarneiro
Post by rfcarneiro » 20 Nov 2018, 14:14
Thank you.
I will try.
