Parallel robot - IK mode
fede
Post by fede » 16 Sep 2019, 22:22
Hi there!
We are two italian guys trying to create a movimentation of a parallel robot.
We understand that we have to use IK mode but we don't know how to set it up correctly.
Our robot is similar to the irb360 that is already built in V-REP.
In our robot thanks to the three actuators the platform can translate remaning parallel to the floor.
If someone can help us with IK mode we will be very happy.
We leave our scene!
Feel free to say anything about our robot...be gentle we are only beginners :)
https://drive.google.com/file/d/1ashn6t ... sp=sharing
We leave also the video of the real robot moving in our LAB.
https://drive.google.com/file/d/1a_TI1f ... sp=sharing
Re: Parallel robot - IK mode
Post by coppelia » 18 Sep 2019, 06:10
how you build the kinematics of your robot will depend how you want to operate it. If you want to operate it in IK mode, then this is pretty straightforward: you simply need to have 3 branches that link together at the platform. So each branch should be:
prismaticJoint --> sphericalJoint --> revoluteJoint --> revoluteJoint --> tipDummy
and you would have the platform with:
platform --> targetDummy1
         --> targetDummy2
         --> targetDummy3
If you want to operate the robot in FK, or in FK & IK, then it becomes more complicted, since you would need something like:
base --> branch1 --> platform --> invertedBranch2 --> tipDummy2
                              --> invertedBranch3 --> tipDummy3
     --> targetDummy2
     --> targetDummy3
Have a look at the various simple examples in scenes/ik_fk_simple_examples
fede
Post by fede » 18 Sep 2019, 15:46
Thank you very much! Now our robot moves correcly!
Just one more question: how can we avoid this type of collision(photo)?
https://drive.google.com/file/d/1skSg8Y ... sp=sharing
Thank you again :)
Post by coppelia » 19 Sep 2019, 08:40
this collision happens because the red joint's range is not large enough. You can detect this if one of the joints is very close to its limit. Or when IK doesn't fulfill precision requirements.
If your IK group doesn't fulfill precision requirements, you can configure your IK group to revert to the configuration prior to calculations.
If you flag your IK group as explicit handling, and call sim.handleIkGroup upon it on a regular basis, then the return value of that function will tell you whether IK was successful or not. Then you could react differently based on that.
