Interface between Velodyne VPL16 and ROS
Rick Shen
Post by Rick Shen » 15 Oct 2018, 19:08
Hi, I am recently using Velodyne VPL 16 for a car simulation. I need to transmit the detected point cloud to ROS via the RosInterface. I am modifying the template code coming along with the Velodyne model. I try to use Rviz to visualize them but there is no point showing in the window even though Rviz shows the messages are successfully received.
These are major points I set for the RosInterface:
  1. Set a publisher using sensor_msgs/PointCloud msg
  2. Publish data with header.frame_id corresponding to the /tf frame_id in simROS.sendTransform, and points = mydata
I am quite new for the Velodyne model, point cloud msg and Rviz, can you please help me with this, especially the following questions?
  1. What msg type I should use, PointCloud or PointCloud2?
  2. Which variable I need to take and publish according to the chosen msg type?
  3. What fields in the msg type are necessary to fill in? And what their value should be? Such as frame_id, width, length, data, what variable in the script should be fed for these fields?
  4. How does /tf information works? What should I make the /tf topic interact with the point cloud?
My code is here:
Init:
        visionSensorHandles={}
        for i=1,4,1 do
            visionSensorHandles[i]=sim.getObjectHandle('velodyneVPL_16_sensor'..i)
        ptCloudHandle=sim.getObjectHandle('velodyneVPL_16_ptCloud')
        frequency=5 -- 5 Hz
        options=2+8 -- bit0 (1)=do not display points, bit1 (2)=display only current points, bit2 (4)=returned data is polar (otherwise Cartesian), bit3 (8)=displayed points are emissive
        pointSize=2
        coloring_closeAndFarDistance={1,4}
        displayScaling=0.999 -- so that points do not appear to disappear in objects
	h=simVision.createVelodyneVPL16(visionSensorHandles,frequency,options,pointSize,coloring_closeAndFarDistance,displayScaling,ptCloudHandle)
        -- Check if the required ROS plugin is there:
        moduleName=0
        moduleVersion=0
        index=0
        pluginNotFound=true
        while moduleName do
            moduleName,moduleVersion=sim.getModuleName(index)
            if (moduleName=='RosInterface') then
            	pluginNotFound=false
            index=index+1
        -- Ok now launch the ROS client application:
        if (not pluginNotFound) then
            local ptCloud_topicName='velodyne'
            lidar_pub=simROS.advertise('/'..ptCloud_topicName,'sensor_msgs/PointCloud')
Sensing:
function sysCall_sensing()
        data=simVision.handleVelodyneVPL16(h,sim.getSimulationTimeStep())
    -- if we want to display the detected points ourselves:
    if ptCloud then
        sim.removePointsFromPointCloud(ptCloud,0,nil,0)
        ptCloud=sim.createPointCloud(0.02,20,0,pointSize)
    m=sim.getObjectMatrix(visionSensorHandles[1],-1)
    for i=0,#data/3-1,1 do
        d={data[3*i+1],data[3*i+2],data[3*i+3]}
        d=sim.multiplyVector(m,d)
        data[3*i+1]=d[1]
        data[3*i+2]=d[2]
        data[3*i+3]=d[3]
    sim.insertPointsIntoPointCloud(ptCloud,0,data)
    -- Publish the Lidar PointClouds to ROS Topic
    if not pluginNotFound then
        pub_data={}
        pub_data['header']={frame_id="velodyneVPL"}
        pub_data['points']=data
        simROS.publish(lidar_pub,pub_data)
        simROS.sendTransform(getTransformStamped(visionSensorHandles[1],'velodyneVPL',-1,'world'))
getTransformStamped Function
function getTransformStamped(objHandle,name,relTo,relToName)
    t=sim.getSystemTime()
    p=sim.getObjectPosition(objHandle,relTo)
    o=sim.getObjectQuaternion(objHandle,relTo)
    return {
        header={
            stamp=t,
            frame_id=relToName
        child_frame_id=name,
        transform={
            translation={x=p[1],y=p[2],z=p[3]},
            rotation={x=o[1],y=o[2],z=o[3],w=o[4]}
I searched the previous discussions in the forum but those API functions are totally different from the current version. I will be grateful if someone can help me through this!!
Re: Interface between Velodyne VPL16 and ROS
Post by fferri » 16 Oct 2018, 11:04
Do you see the data arriving at the /velodyne topic?
To test, run the following in a terminal:
rostopic echo /velodyne
If yes, then it might be a problem of choosing the correct frame in RViz (try selecting the velodyneVPL frame).
If in RViz you select the /map frame, but no tf frame linking /map to /velodyneVPL is broadcasted, RViz won't show you anything (it will show an error in the PointCloud display however).
Rick Shen
Post by Rick Shen » 16 Oct 2018, 17:27
fferri wrote:
16 Oct 2018, 11:04
Thanks for the reply! I have checked that /velodyne topic has data arriving and RViz can find the /velodyneVPL frame. Therefore, I am now paying more attention to the msg type.
Should I use PointCloud2 or PointCloud?
If it should be PointCloud2, which of these fields are mandatory and which are neglectable, and how to fill them from velodyne template code:
  • std_msgs/Header header
  • uint32 height (Where should I find heigh and width in velodyne template)
  • uint32 width
  • sensor_msgs/PointField[] fields
  • bool is_bigendian
  • uint32 point_step
  • uint32 row_step
  • uint8[] data (why it is uint8 here. If I assign results from velodyne to it, I only see a lot 0, 1 in rostopic echo)
  • bool is_dense
If it should be PointCloud, how should I do with these:
  • geometry_msgs/Point32[] points
  • sensor_msgs/ChannelFloat32[] channels
Especially, the "points" field requires geometry_msgs/Point32[]. When I want to feed it with results from velodyne, error shows up and saying it is not the right type. How should I convert it?
Post by fferri » 16 Oct 2018, 17:44
Whether you should use sensor_msgs/PointCloud or sensor_msgs/PointCloud2 depends on which message types the receiving part can support.
If it is RViz, it is capable of displaying both.
The main difference is that PointCloud contains point data stored as arrays of points and float values, and it is simpler to fill. PointCloud2's data is stored in a binary blob, and more efficient in terms of space, but you have to store additional information such as point size in bytes (point_step field), stride (row step field), and so on; all of those fields are mandatory, and the documentation is contained in the links you posted, i.e. http://docs.ros.org/api/sensor_msgs/htm ... loud2.html.
See also https://answers.ros.org/question/207071 ... in-python/
Post by fferri » 16 Oct 2018, 23:02
Rick Shen wrote:
16 Oct 2018, 17:27
since the points field is an array of Point32 message, it should be something like this (in Lua):
{points={{x=0.0,y=0.0,z=0.1},{x=0.1,y=0.0,z=0.12},...}}
Rick Shen
Post by Rick Shen » 16 Oct 2018, 23:07
This ROS answer is so helpful! Now I can properly set the data structure and I can see them in Rviz. I use PointCloud msg type since I think PointCloud2 may need some special conversion.
A new problem, after the simulation starts, there will always be a message box bumping out and saying my velodyne code has "Abort execution". The detection is running very slow that it takes a lot of time to finish the detection in the four direction. The effect is very bad that I can see the point cloud in each direction stays for about 3 sec and then the next one comes. This happens also in Rviz.
Below are my complete code. Is there any method to speed up or it is just because my laptop is bad? (It is indeed an old laptop and I am even using Virtual Machine for ROS and Vrep)
    isOpen=sim.getScriptSimulationParameter(sim.handle_self,'isOpen')
    if (isOpen==1) then
        for i=1,4,1 do
        frequency=5 -- 5 Hz
        pointSize=2
        moduleName=0
        moduleVersion=0
        index=0
        pluginNotFound=true
        while moduleName do
            index=index+1
    return {
        header={
            stamp=t,
            frame_id=relToName
        transform={
    if (isOpen==1) then
    if ptCloud then
    point32 = {}
        data[3*i+1]=d[1]
        data[3*i+2]=d[2]
        data[3*i+3]=d[3]
        point32[i+1]={x=d[1], y=d[2], z=d[3]}
        point32 = {}
            pub_data={}
            pub_data['header']={stamp=sim.getSystemTime(),frame_id="velodyneVPL"}
            pub_data['points']=point32
function sysCall_cleanup()
    if (isOpen==1) then
        simExtVision_destroyVelodyneVPL16(h)
BTW, I hope the code can be helpful for anyone else who wants this interface.
