Change color of a primitive shape from remote Api (Matlab)
DavideIng
Post by DavideIng » 11 Oct 2017, 17:11
the following it's the code that I have wrote on matlab to get the absolute position of the epuck on the scenes and to try to change the color of a plane (primitive shape) from a remote Api (Matlab), this second instruction doesn't works.
disp('Program started');
vrep=remApi('remoteApi'); % oggetto remoto chiamato vrep
vrep.simxFinish(-1); % chiusura di ogni precedente connessine
clientID=vrep.simxStart('127.0.0.1',20001,true,true,5000,5); % crea una connessione con vrep
if (clientID>-1) % se la connessione è stata stabilita correttamente
    disp('Connected to remote Api server');
    %Handle
    [returnCode,e_Puck]=vrep.simxGetObjectHandle(clientID,'ePuck',vrep.simx_opmode_blocking);
    [returnCode,e_Puck1]=vrep.simxGetObjectHandle(clientID,'ePuck1',vrep.simx_opmode_blocking);
    [reurnCode,Plane_color]=vrep.simxGetObjectHandle(clientID,'Plane',vrep.simx_opmode_blocking);
    % Get signal (RgbPlane)
     [returnCode,PlaneColor]=vrep.simxGetStringSignal(clientID,'color',vrep.simx_opmode_streaming);
    %Position
    [returnCode,ePuck_position]=vrep.simxGetObjectPosition(clientID,e_Puck,-1,vrep.simx_opmode_streaming);
    [returnCode,ePuck1_position]=vrep.simxGetObjectPosition(clientID,e_Puck1,-1,vrep.simx_opmode_streaming);
    %Color
    [returnCode]=vrep.simxSetStringSignal(clientID,'color',{1,0,0},vrep.simx_opmode_oneshot); % set red
    for i=1:inf
    [returnCode,ePuck_position]=vrep.simxGetObjectPosition(clientID,e_Puck,-1,vrep.simx_opmode_streaming); %-1 return the absolute position
    disp(ePuck_position);
    disp(ePuck1_position);
    pause(0.1);
The following is the non Threaded child script of the plane:
handleWall = simGetObjectHandle('Plane')
number result,tablergb=simGetShapeColor(handleWall,'Color',sim_colorcomponent_ambient_diffuse)
simSetShapeColor(handleWall,nil,0,tablergb)
Someone could help me to figure out why It doesn't change a color of the plane from Matlab?
Many thanks
Davide
DavideIng
Re: Change color of a primitive shape from remote Api (Matlab)
Post by DavideIng » 12 Oct 2017, 15:43
One of the main issue with these scripts is that the Array InitColor (Initial color of the shape on the scene) has not been got in matlab ( not defined in matlab). How can I fix it? Just define a matlab Array with the same name?
Many thanks
Davide
Post by coppelia » 13 Oct 2017, 08:27
use simxCallScriptFunction to change the color of an object. More details are here. Also, make sure to test the demo script programming/remoteApiBindings/matlab/matlab/complexCommandTest.m
