Using table value as an arithmetic variable
javl0p
Postby javl0p » 19 Jun 2017, 13:21
[I HAVE ALREADY FOUND A SOLUTION, DON'T BOTHER TO ANSWER]
Hi coppelia,
I'm implementing some code in VREP in which I have to do some calculations with the measured variables I obtain from the simulation.
Here the code:
harrington_f=function(y,limit)
ub=limit*0.9
lb=limit
dlb = 0.01
dub = 0.99
lb = 3500
ub = 1000
        alpha = math.log(math.log(dub)/math.log(dlb))/(ub-lb)
        beta = math.log(-math.log(dub))-alpha*ub
        varargout = {math.exp(-math.exp(beta+alpha*y))}
return varargout
call_objective_function=function()
get_posandtorque()
    for i=1,7,1 do
    des=harrington_f(torques[i],limits[i])
    real_torques[i]=des
a=real_torques[1]
b=real_torques[2]
c=real_torques[3]
d=real_torques[4]
e=real_torques[5]
f=real_torques[6]
g=real_torques[7]
s=1-(a*b*c*d*e*f*g)
return s
So, two functions are created. Function call_objective_function call the previous function harrington_f. The problem comes when I work from data stored in tables. In this case, i have torque measurements for every joint, and I use those measured torques in my calculations. However, I get this error message:
Lua runtime error: [string "SCRIPT LBR_iiwa_14_R820"]:43: attempt to perform arithmetic on global 'a' (a table value)
It's weird that when it runs the function harrington_f I also use table values as numeric inputs and LUA does not recognize that as an error.
What could i do to get rid of this error message?
Thank you very much!!
Return to “General questions”
Who is online
Users browsing this forum: Bing [Bot], Google [Bot], R2D2 and 26 guests
